I posted the following on the BREAKTIME site as well:
For the last four years I have been building a vacation cabin up in Alipne, Arizona. I am about ready to install the kitchen cabinet doors. I built the cabinets myself, using 3/4″ oak plywood for the tops & sides, 1/4″ plywood for the backs. 1/4″ oak edgebanding on the fronts. I am having the oak doors made from a doormaker in Chandler Arizona, about $14.00 s/f of door. I am hoping the doors will be ready this week. I will be using 110 degree & 105 degree Euro-style hinges ($1.95 / pair from Grizzly – I thought that was a deal compared to what they charge at HD & Lowes). Doors will be finished with Watco and 5 – 7 coats of a wipe-on poly.
I am looking for any special tips/techniques you all use to install the cabinet doors. I have a small bench-top drill press I plan on using for the 35mm boring bit. Any suggestions would be appreciated. Thanks. Adam.
Here’s a pic of the CABIN: http://hometown.aol.com/azaharchuk/myhomepage/artgallery.html
I have recently been plugging and redrilling some refinished cabinet doors for a customer. I have been pretty happy with my drilling jig from Rockler (http://www.rockler.com). It costs $32.99 for the single JIG IT system (you have to get a 4" 35 mm drill bit too). This is faster and cheaper than the setup time on my shopsmith would be worth. I have found it quite accurate.
You might ask your doormaker how much he would charge to drill and attach your hinges for you. He's probably already set up to do this. It is easy then to mark and drill your pilot holes for attachment to the cabinet.
If the tips that suggest don't help feel free to Email me at masterwoodworker@attbi.com and ask me the problem that you might still have.
I fit doors / drawers for a furniture mf for 6 years and the tips may or maynot help.
It might depend on the type of hinge that you chose, most people chose to use a spring hinge with 1/4 " lapped doors. Most doors I've installed . Start the hinge 2" to 2 1/2 " from top and btm. this will depend on the height of the door or your desision.some times I've set up a block with the hinge holes where the top hinge falls. this block made to hang on the edge of the facing and just use a small piece of 1/8" ply big enough to cover the area to drill where the hinge holes will be. and that will almost always come the same on both sides, and so the doors will come out even on top and bottom. I also use a vix bit so that the screw holes are always centered. Perches a Vix bit in most woodworking supply catalogue. Hope this helps!
I'm a full time furniture /cabinet builder, 25yrs exp/ Grand Rapids,MIch
