hi i’m new with the forum and i have a question for all of you out there.
I was wandering witch of those two kind of router would be best to buy, a 2.5hp or a 3.25hp. I will use it to do pretty much every thing from mortise,inlays to cabinet doors etc… And I was looking betwin bosch, hitachi and porter cable!!!
thank you in advance for the tips. Phil!
If it were to be used only in a table -the bigger the better. Since it sounds like it will be used hand held as well, I would suggest one of the combos available from the three companies you mentioned. I have 9 routers and think you can't have too many.
Regards
Jerry
I have the Hitachi 3.25 and I love it. Forthe price, I don't think there is a better plunge. I use it mainly for table use. I've done a little with it as a handheld and it's not too heavy.
woodphil,
As you do more woodworking, you'll probably end up with more than one router. This might sound funny to you now, but I have two, and I'm thinking of a third. I'm sure there are other people who have three, four, five, or even more routers.
Here's my router team:
Porter+Cable 3.25-HP, model #7518.
This one is dedicated to the router table. It's a workhorse that has never failed me after three years of hard work. And the one I have was bought reconditioned! For a router mounted permanently in a table, you just want it to plough through wood when asked. You want it to be powerful and you want it to have very little runout. I recommend the Porter+Cable 7518.
Here's a link: http://www.amazon.com/exec/obidos/tg/detail/-/B0000222V3/qid=1129654003/sr=8-2/ref=pd_bbs_2/002-6200427-9474418?v=glance&s=hi&n=507846
Festool OF1400
My second router is for general hand-held use. This one needs to be a plunge type. It needs to be lightweight and accurate, with easy bit changes. Of course, it should also be powerful, but does not need to be a brute like the table-mounted one! The clear winner in this category is the Festool OF1400.
Here's a link: http://www.festoolusa.com/category.aspx?ID=4
???? Next ????
There are times when I need to do finer work, and I am about to get a trim router for this, aka laminate trimmer. Great for hinges, inlays, and, what do you know, trimming laminate! I'm considering the new Bosch Colt.
Here's a link: http://www.coastaltool.com/cgi-bin/SoftCart.exe/a/bosch/pr20evsk.htm?L+coastest+dvmh8927ff356435+1129716812
It all depends on what you will use it for the most. In a table mount - again the bigger the better. If mostly used hand held go with a 2 1/4 HP kit.
I have the Makita RF1100 and the only thing I do not like is that it does not have the option for below table height adjustment. I also have a laminate trimmer that I use for light duty routing and for detail work I have a Dremel with a router base, If you can call it a router, I also have a rotozip.
If I had it to do over, I would have gone with the Porter Cable or the Bosch 2 1/4HP kit. - whichever way you go, make sure that it has the below the table height adjustment - that way you do not have to spend extra for lift or have the hassle of height adjustment.
Phil,
Get the Hitachi M12V for your table and the Bosch 1617EVS kit for handheld operations. I have those as well as a couple of HF trim routers (the ones the always have on sale for $20). I keep a flush trim bit in one trim router and a 1/4" roundover in the other. I also have a PC trim router but use the HF more frequently because they are easier to set up.
Bill Arnold - Custom Woodcrafting
Mensa Member
Click Here if you're interested in a good, inexpensive website host.
Have the dewalt 625, have been pleased with it.
Troy
