Hi:
I am building a cabinet/entertainment center for a new plasma tv that we purchased over the holidays. I am using the general design in these plans:
But am designing it as a built-in and intend to add some book shelves around and above the TV later. The plans call for a 1/4″ back but since the back will be attached to the wall, I thought I would save a few bucks and omit that part. However, in reading Andy Rae’s book on Furniture and Cabinet construction, he suggests a cabinet may sag over time if you don’t use a back.
Given that this is a low profile unit (20″ h x 15″ D x 68″ w) and the fact that it sits on the floor and is unlike to hold heavy loads, do you think I am likely to get any sagging if I leave off the back?
Cheers,
Velo
A 1/4" back isn't going to do very much to prevent sag although it may help a little if it's screwed or stapled to the carcass. It can, however, provide a lot of support against racking.
Personally, I always put a back in a cabinet with an open front - if just for appearance. Most of the time 1/4" is fine, but I'll go to 1/2" if there are structural issues.
the 1/4" backer serves to keep the unit square. if you omit that piece just screw a 1x3/4" cleat to the wall and attache your horizontal members onto that
Hi Velo ,
The design in the picture shows 3 partition walls in the cabinet . You said a built in , that means the cabinet will be screwed to the walls correct ?
As long as you support under the partition walls underneath all the way to the floor , I see no where for the sag to happen , you will be fine without a back and once screwed to the wall the back serves little purpose other the visual on some works .
If this was to be a free standing unit then a back would be a must imo .
BTW it is a nice looking cabinet , how you gonna make those doors ?
regards dusty , boxmaker
Thanks to all for the advice
Dusty:
Yes, I am going to attach it to the wall along the back and on the right side.
I have not yet decided about the doors. I really like the lattice appearance but my wife seems to prefer frosted glass. The plans include a very basic procedure on milling the lattice but I have not spent much on it yet.
Thanks again
Cheers,
Velo
