Good morning,
My friend thinks he can build a bookcase for cheaper. He thinks my calculations are way off.
Here are the measurements for the Large bookcase:
From stock 1″ X 10″
cut: 2 pieces 8 1/2″ X 54 1/4 long (sides)
4 pieces 8 1/4 X 30″ long (shelves)
Top: 1 piece 10″ X 33″ long (leaves enough overhang for a decorative edge)
1 piece 3 3/4″ X 31″ (for the bottom)
Pine Panelling 1/4 inch thick)
8 1/2 pieces needed for the back of the bookcase. I’m assuming the panelling comes in 4 inch widths (nominal) (actual) 3 1/2 inches wide)
common #2 $6.75 14 sq.ft. common #1 $12.15 14 sq.ft.
If you round up those numbers you end up with approx. (400 inches) which I divided by (12) to give me the number of feet I need. This project would require 33.33 ft of lumber. 33.33 X 2.65 = $88.32
Knotty pine $1.10 per ft. Clear pine $2.65 per ft
$88.32 (clear pine) Plus $12.15 for (common #1) pine panelling. You can’t buy it seperately, it comes in pkg. I can always use the scraps for building nightstands.
That doesn’t include the cost of #8 8 1/2 inch Robertson screws or woodplugs. So for around $100.00 I can build this bookcase.
I don’t think I can build a bookcase this size for much cheaper. Unless I build it out of knotty pine and go with common #2 panelling. Is it better to go witht Clear pine or would knotty pine do the trick??? and what’s the difference between common #1 and common #2 panelling? I assume the cheaper grade has more knots and resin. Total Cost of Project = $ 100.47
Tell me my calculations are not that far off the mark. LOL
Wendy
Wendy,
I didn't run your math, it looks like you've got a good handle on that. However, you do need to figure in waste. For example, to get an 8 1/2" board, you need to buy a 1 x 10, etc. You also will find knots in the most inconvenient places for your joinery, i.e. you'll need to add a high waste factor for this type of wood, I'd go 20% to 30%.
Good luck,
Norse
Wendy,
I kinda roughed out the numbers and pretty much concur with your calculations....you need about 25' of usuable board feet and with waste 33' would be a relatively safe number. You could make is cheaper with plywood...maybe half the cost...and pine or hardwood trim....but I think you know that.
