I’ve been on a budget on everything I do. Having some extra scrap woods and die cast extenstion table I decided to make a router table that would be better than my previous ones that I’ve bought . My garage is only 11’x17′. I ran out of room for the router table so I decided to mount it above the workbench. It’s not the best place, but it seems to work for me so far. I tested it and it work quite well
Edited 9/6/2009 6:21 pm ET by Quang
Edited 9/6/2009 8:17 pm ET by Quang
Smart idea. Sometimes we get caught up with having the full sized versions of everything and then spend half of our time dodging them. Love it.
Chri7s
What a great idea, I like it! Look like a hefty table, how much does it weigh?
I think it weights around 30 lbs. I basically took 2 extension wings to a table saw to make it.
Q
Edited 9/9/2009 12:41 am ET by Quang
Quang,
That setup is pretty close to brilliant. Nicely done and thought out..
Zolton
If you see a possum running around in here, kill it. It's not a pet. - Jackie Moon
Thx
Q
I like your idea, but it made me wonder...
How come the wall above your bench is so empty? Where's all the stuff that's crowding my wall?
David Ring
http://www.touchwood.co.il/?lang=e&id=1
I'm thinking about adding a small cabinet (no door) right behind the router table. I can store router bits and wrenches for the router there.
What stuffs do you put above your work bench ?
Q
Edited 9/9/2009 12:42 am ET by Quang
Quang,
Very nice. Very clever! That solves a large footprint problem for many home shops. I didn't see, but does it have a lock or a pin on the fold down leg hinges? From a safety standpoint, that would be a plus, I think. The only other things I would like is a way to quickly remove the router,
Excellent!
BB
I'm still thinking about a small cabinet behind the router that will lock the router table. Definitely I don't want the router to fall down on me. Right now the table is tilted toward the wall when it's stowed.
I'm kind of stuck on attaching the router base to the table using screws. For now I just remove the router via the quick clamp on the router base. I bought the router lift ($169 Rousseau) for quick removal purpose, but I returned it because it was made out of plastic (phenolic ?) material. The aluminum base router lift would cost much more. I couldn't justify $399 for a router lift.
Q
Edited 9/8/2009 11:55 pm ET by Quang
Edited 9/9/2009 12:44 am ET by Quang
