I’m wondering if anybody can offer some advice on a bow front door project. I used bent lamination for the front, 3/4″ thick. I am using 1/2″ material for the sides. I started out by cutting the tails on the side pieces. I am looking for suggestions on how to proceed with the pins on the front for the half-blind dovetails. Any info would be much appreciated.
Proceed as you would if the front were straight. I would give the backside of the front a 1/2" wide flat area that's square to the end. Once that's done mark the position of the pins using the sides and chisel them out just as you would a straight front.
Lee
Furniture Carver
That sounds good. How about any suggestions on ways to waste a lot of the material with a router or something before finishing off with the chisels? Thanks very much
You could chuck up a 1/4" or 1/8" straight bit and after marking for the pins hog out some waste.
LeeLee Grindinger
Furniture Carver
I finished the glue up of the bow-front drawer last night. I cut the tails in the sides first and then planed a flat on the mating side of the front piece. After marking the pins and chiseling them out, I was surprised how well it came out and it wasn't as difficult as I expected. Thanks for the guidance.
That's good news, Ken, but I was just on the sidelines telling you what you already knew.
LeeLee Grindinger
Furniture Carver
Now this is what this site is for! Getting advice from experienced craftsman! I like it!
Terry - Delray Beach, FL
