Do any of you have experience with Blum 120 degree face frame hinges (3-way adjustable)? I tried another brand, but they couldn’t be adjusted to get the hinge side of the door close to the face frame. They left a 1/4″ gap between door and face frame. This was a 1/2″ overlay setup. The Blums apparently adjust in that plane, but I wonder how much and whether they can be made to contact the face frame on the hinge side (and still open). Thanks for any help.
Typically there is a 3mm gap between the door and FF using the Blum hinges. You can tighten the gap between the door an dFF,but you may need to adjust the boring distance from the side.
