I am at the point where I am ready to finish a speaker project. I would like to match the black finish of my other stereo equipment. I tried using some ebony stain (on a test piece) and it didn’t get near dark enough. I’m shooting for BLACK , but still want to be able to see the grain structure. I know that black paint will get it dark enough, but I’m affraid that paint will also fill in the grain. Is there a true black stain out there that will make it truely black. The material is red oak plywood. That’s in advance, for any help you can give me.
See the current issue of FWW (140) on page 130--a shopmade ebony stain that works great on oak (and any other wood high in tannins).
*see black dyes (not stains)
*Here is what I did to create the effect you are seeking. I used a Krylon Black in the spray can. It is so thin that it will color the wood but not fill the grain.
*Scott,I just finished a job that required black counter tops. I used red oak ply. My first attempt, on scrap, was with a water based black dye that yielded bad results. I followed the manufacturer's directions, but the dye would not penetrate the wood properly. I next tried a black water based color stain "Country Color" brand. Results were very good after the second coat, completely Black with the grain patterns visible. I top coated it with polyurethane. Looks great. Give it a try.
*When I want to turn oak black I ebonize it. Try putting a few iron nails in a jar of white vinegar. After a few days wipe the vinegar-nail solution on the oak, and right before your eyes it'll turn very dark black. It may have a slight purplish cast to it, but when you apply a finish to it, it turns out black, and I mean black.If you want to kill the process (on another project) before it gets too dark you can neutralize the vinegar-nail solution with household ammonia. Try it! It's fun. I tried getting oak to turn green by soaking copper in vinegar, but it didn't work. Something chemically isn't happening that would require the process to work out. Best of luck!
