I live in Louisiana where rust is an big issue. I do use paste wax which is better than nothing on table surfaces but as far as my hand tools go it’s practically useless. I would like to see an article on rust prevention, by way of a tool test or review. it would be great if it included multipe products….Waxes, Camellia oil, Boeshield Rust Free and T-9, TopCote, DryCote, etc.. I would like find a solution to my rust problem but I don’t want to waste money trying all of these products.
Rust
Take a look at this site. http://www.theruststore.com
Humidity Control
Since you are in Louisiana where it is not only humid but hot, do you air condition your shop?
The primary function of air conditioning is to control humidity. If your shop is reasonably tight and well insulated, You should be able to conrol the humidity. I think controlling the humidity is the only way to prevent rust in very humid environments. One thing that frequently happens in air conditioned spaces is the people will run the air conditioning while they are working in the shop and cool the shop to a temperature below the dew point. When they finish working, they shut off the air conditioning and open doors and windows. Since the tools are at a temperature below the dew point, moisture in the humid air will condense in small droplets on the tools. The better practice would be to use a thermostat to control the air conditioning, check a weather site to find the dew point (i like Weather Underground), and set your thermostat a few degrees above the dew point.
If you don't use air conditioning I would clean blanchard ground tables with Rust Free or Naval Jelly and a Scotch Brite. The I would apply Turtle Wax (paste) or perhaps TopCote. For cutting tools, I think l sharpen and coat them with Camellia Oil.
Dew Point
Good info Ron -
SA
I do not have air conditioning in the shop, so I run a large attic fan to circulate air. You are correct about the heat combined with humidity, oh and my sweat. I just purchased a window unit for when it gets really hot but my shop is not climate controlled. I will look into the products suggested.
