Anybody have any good ideas, beyond weather stipping and tarps, for keeping the cold from coming in through sliding barn doors? I’m willing the keep them closed and locked for the winter. I’m looking for a “seasonal” solution. I guess I’m looking for something that is as air-tight as possible. The opening with both doors closed is probably about 9′ x 16′. Any ideas greatly appreciated.
I sandwiched 1" x 4' x 8' solid foam insulation between a 1/2" sheet of plywood and 5/8" sheet of T-111 on the outside. For the sides I ripped some 1' strips, of course you will need to slice 1 1/2" off the insulation. This worked quite well but your dimensions are a lot bigger than mine.
My RO was almost exactly 4' x 8'. You could adapt my design for the size you are dealing wiht as the stiffness of the doors comes from the skins not so much as the insulation. Getting the 9' height would be the biggest challenge but not a show stopper by any means.
My door is a traditional sliding barn door as well. To seal around the edges, I used weatherstripping. The catch is designed so that when the door is closed, it pulls the door in to engage the weatherstripping so as to keep the wind out. Seems to work quite well.
Also, you will need to reinforce areas for the the hangers on top and wherever you want to mount a door handle. For this I cutout blocks and inserted 1" boards that were captured by the mounting screws for the door hardware. Do this before placing the last skin! Yes I did make that mistake, but recovered B4 it turned into a mess!
Edited 3/20/2007 12:10 pm ET by KiddervilleAcres
Thanks. Sounds like a great solution. With a little figuring I think I may be able to adapt your design.
Battens. Or look at garage door insulation.
Edited 3/20/2007 12:11 pm ET by ajoe
