I have been googling for a while now and trying to find a plan on building a banker’s
chair. Anyone seen one anywhere?
This might be a stretch but could you find an old, used one and use it for patterns? Even one that isn't complete could work for that.
M,
Is "banker's chair" an oak swivel arm chair? If so, having just refinished an old junker for my wife, Dave's suggestion for using an existing chair for templates is certainly valid. Without a full scale mock-up, getting all the angles for cutting and drilling correct would be a NIGHTMARE running in overtime.
Best!
-nazard
m,
Seems I've seen a few old ones that were upholstered with a dark leather .
Wood showing and upholstery , is it similar ?
dusty
yeah similar to this one.
http://www.everythingofficefurniture.com/ofchofst10de2.html
or this one.
http://www.potterybarn.com/products/p8169/index.cfm?pkey=xsrd0m1%7C20%7C%7C%7C0%7C%7C%7C%7C%7C%7C%7Clibrary&cm%5Fsrc=SCH
Barrister's or Bankers Chair
I also was looking for a set of plans and after much looking I have elected to reverse engineer a set in autocad that is almost complete. I do need to mock up the angles where the back legs meet the seat, but I should have them complete in a couple of weeks. Would you like a pdf version of the drawings? They will not be exact since they were created using ratios of observable part, but I think they will be useable for our purpose. You do understand the bottom bracing of the seat and the back will have to be either steam bent or laminated.
Jim
I've been trying in vain to find the same type of plan myself My interest comes from my grandmother's old bankers chair I pulled out of the trash years ago. It had come apart in all it's individual parts and had been assembled with dowels .
I was about 15 at the time so I didn't know much about clamping and so on. I glued it back together and it lasted maybe a year before my nieces and nephew finally destroyed it and someone finally pitched it out when I was away . Probably thousands were made back around the turn of the 20th century so the plans must exist somewhere ,but finding them has proven elusive to say the least .
