Having used bandsaws to work sheetmetal as well as wood, what is the main difference between the two saws? My reason for asking is that I’m going to purchase one, likely the LaGuna, and was wandering if it would be practical to simply get a set of blades for wood and another for metal. I hate to spend big bucks on a machine exclusively for wood as long as I also do sheetmetal work. If the difference is simply speed, is there a machine out there that anyone knows that might be variable speed? Many thanks in advance
I've cut through 3/8" mild steel on the same bandsaw that I use for woodworking. Different blades, of course. Cutting 18 ga is like cutting butter.
Rp
The primary difference is blade speed. My metal bandsaw has a speed of about 300 fpm that is a bit fast for mild steel. But is still serviceable. My wood bandsaw in over a 1000 fpm and that is way too fast for steel in any alloy. If you could solve the speed problem I still wouldn't recommend using the same saw for metal and for fine wood. My metal saw gets steel dust/chips inside the guide block mechanisms, all over the screw adjustments, embeds into the tires....... it's simply a mess. Also, the table gets all gouged up by errant chips of metal that get caught under the piece being cut. What was once a clean and pretty machine is now rather rough and ready. It's service isn't really compromised, it just doesn't adjust smoothly and it would rough up any piece of fine wood I were to run over its table. I heartedly recommend that you get two different saws.
A wood saw can be converted to cut steel but once done, it would be tough to go back.
Sapwood nailed it, waljay. You can do it on a drill press as you have belts for changing to slower metal cutting speeds. Have you ever noticed that most hand held 1/2" drills and larger run at an average of 500-600 rpm. They are primarily for metal and even then a lubricant should be used to avoid over-heating as one would in a machine shop.
I have seen people that get away with cutting aluminum (which is soft enough to sand) on a 2 speed wood band-saw that the blade speed can be slowed a bit and changing to a metal cutting blade. But as sapwood, I wouldn't do it personally on my saw.
My BIL is a shop foreman at the machine shop at Delta Airlines here in Atlanta and we have metal cutting BS's at my job in "muscle car restoration". I have no reason to clog my wood BS with metal shavings that will eventually find it's way onto WW projects and take away life expectancy of a wood machine.
Regards...
Sarge.. jt
