I have just finshed a hurricane damaged room and want to hang crown to the walls but there is no nailing surfaces is mastic sutable and how do you hold it in place while it sets up
charlie
charlie
Pretty sure the right way to do is to put up some blocking, and nail to that.
How can there be nothing to nail to? What's holding the walls up?
thanks, of course there are studs but they are below two thickness of dry wall and hard to fine
Charlie
Hi,
I suggest you put nailing blocks where the studs are or run a piece of lumber behind where the crown moulding will go. That way you can nail the moulding wherever you want to. Given your line of questioning, I would also suggest premade corner blocks for inside and outsite corners. This eliminates the need for coping your miter cuts. A 90 degree butt joint is all you need. Lowes has them in various sizes. If you are opting to glue/adhese the moulding, I recommend a manmade material like foam or styrene. Should stay put for a long time.
Good luck.
Ken
"Do as you would be done by." C.S. Lewis
Try a product called "PowerGrab" mfg. by Loctite. All the trim carps rave about it.
It comes in a tube (like caulk), and functions like a construction adhesive -- but it's thinner, and water soluble (so you can wipe off any squeeze out with a damp rag), and its "grab" is almost instaneous.
"I would never die for my beliefs because I might be wrong."
-- Bertrand Russell
Ditto the power grab, also cross pin into the drywall to hold the molding until the adhesive sets.
