I have been trying to attach a photo. The attach files button doesn’t do anything.
Am I doing something wrong?
Alan – planesaw
Alan – planesaw
It's working fine for moi. Do you have a PopUp blocker working in the background??? That might cause you a problem. When you click on the Attach Files button, you should get a pop-up window with instructions.
Another thought: Check behind the Knots window in case the pop-up is actually popping "under" for some reason.
Thanks. I do use Norton firewall. I would think that is a common enough piece of software that Taunton would account for it.
But, no, no window pops up. I will try again, per your suggestion, and look behind whatever I can find.
Alan
I turned Norton off and got the pop up you are talking about. But, that concerns me that I have to turn Norton off for this to work.
But, thanks for the lead.
Alan - planesaw
You might try dropping a line to [email protected] and see if they have any suggestions. I use Norton's antivirus stuff, but have not used their firewall. Is there an adjustment in it somewhere maybe? forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Like the television, it is either on or off. Will drop them a note.
Thanks again. But, got to photos attached. Cherry cradle in the gallery.
Alan - planesaw
Alan
I'm also running Norton Internet security and haven't had teh attachment problem you're referring too. I have to ask, do you have Norton set to allow the action you were trying to do? were you waiting long enough for the attaching process to complete, early on I found attaching took muuch longer than I expected.
Ian
