I recently got 2 slabs of countertop-thickness marble from a kitchen design store for a great deal because they were scraps. They’re both 14″ x 18″ and I’m going to use them as tops for 2 bedside stands.
My question is- how can I attach these to the tops of my bedside stands? Is there special hardware, or do I epoxy a fastener to the bottom side of the marble?
I’m a relative beginner in woodworking- experienced enough to make a good table or drawer case, but lacking in some details. I appreciate the help!
Kevin
Use epoxy it works great.
Steve - in Northern California
The granite and marble kitchens I've been involved with have been attached with silicone caulk, not latex, silicone.
LeeLee Grindinger
Furniture Carver
Silicone caulk/adhesive.
Howie and Lee, you are right, that is what I've used for counter tops also. The primary reason for that is so the counter tops can be changed if damaged without destroying the cabinets. Rarely would anyone try to lift a counter top so this works well.
I think in this case the epoxy might be the better choice because the end tables will likely be lifted by the tops when being moved for vacuuming etc. On the marble table that I built, I experimented with several different adhesives but settled with a concrete to wood epoxy made by JB Weld. We moved the table several times without any problems.Steve - in Northern California
Hmmm, Steve, so you attach all your tops in a permanant fashion?
Lee
Lee Grindinger
Furniture Carver
Edited 7/15/2002 8:24:18 PM ET by LeeGrindinger
You said : "Steve, so you attach all your tops in a permanant fashion?"
I don't think I said that.Steve - in Northern California
You guys have been a great help. Here's what I'm thinking- you can tell me if I've got it right:
I'll mill a rabbet on the inside of the tops of the rails of the table and install plywood corner blocks, just like on a kitchen cabinet, and that should give me a good flush surface to apply the adhesive. I think I agree more with the epoxy idea, since it will be a piece of furniture and will get more handling than a kitchen countertop.
I could see where you definitely wouldn't need epoxy in a kitchen situation, since the slab would be so heavy as to resist movement on it's own. I think the size of my top and the furniture aspect will call for something more sturdy.
Thanks so much again,
Kevin
Steve, you are probably correct that an epoxy would be stronger, but in the shop I was involved with, we use silicone adhesive on lots of stuff that was used on boats without any problem. Let me also say, that when you try to remove anything from a boat that has be bedded in silicone adhesive, you will find that it has an enormous amount of strength.
O.K. I'll buy that. On the marble table that I did I felt I was using the epoxy for structural purposes. I epoxied slotted blocks to the marble then screwed through the blocks into the skirt. When I tried using silicon the blocks moved around too much for my comfort. It probably would have been o.k. I just didn't feel comfortable with it. Steve - in Northern California
Make sure the marble is supported every two feet or so from beneath to prevent cracks.
Frank
I agree with the others that silicone or epoxy would work fine; the problems start if you want to disassemble the table for moving or storage. Epoxy such as JB weld makes a bond stronger than the wood, and thus might damage the table if you forced the top off. Silicone caulk is messy and a pain to remove prior to reassembly.
For a no fuss alternative, rabbet plywood "buttons" into the tops of the legs, and screw them down. Make them long enough so that they extend about an inch inboard. Drill pilot holes for masonry screws ( I used 5/8 for a similar project).Place the marble slab upside down on the workbench and center the frame on the slab. Mark through the pilot holes with a sharpie, and use a masonry bit to drill to depth. Fasten using hex type masonry lag screws. This way the tabletop stays on securely, yet is easily disassembled with a ratchet.
One more tip: keep an old windex bottle full of water handy while you drill the marble and spray the bit continuously to keep it cool.
Edited 7/17/2002 4:31:42 PM ET by JALLEN9301
