So, I’ve cut the finger joints in my tool cabinet,(http://www.taunton.com/finewoodworking/FWNPDF/011188040.pdf) and I’m ready to do a glue up. The top and bottom pieces are 13.5″ x 30″ and the sides are 13.5 x 48″. I did a dry fit and everything went just fine. Took it apart, took a break, came back out and glued up one corner, and the dang thing (with glue of course–Titebond 3)would not go together. It was then that I realized I never marked the corners from the dry fit. So I was able to clamp it together and it was a nice tight fit. It’s about 1.5/2 degrees out of square, but I did a dry fit with the rest of the corners, and I am able to rack it all square. I’m planning to glue the other short piece, get it square and let it dry and then glue the last side together, square it up and be done. Anyone have a better way from here on out? What’s the old saying, “I don’t make mistakes, I make alterations”? Thanks in advance. Tom
You can make up or purchase some corner clamping blocks. These help keep things square. It's difficult to do more than one corner at a time with finger joints, you have to move real fast. White and yellow glue can make the lumber swell. Try using liquid hide glue. You can see a couple of corner blocks in this picture, Rockler sells some plastic ones. They are a big help.
Thanks. I thought there were corner blocks, but had forgotten about them. Trying to get the glue spread on all the surfaces and then put together is a challenge, and I want the remainder of the joints to be square. I'll swing by Rockler Friday. Tom"Notice that at no time do my fingers leave my hand"
This isn't something I'd like to try one side at a time as I think it's harder to keep it square. If you go that route with the rest I'd put the other sides in dry as you go, then pull them back off and do the next one. If you lay the opposing sides together and clamp them, you can get glue spread on the fingers 2 at a time before glue starts setting up. It also helps to make some clamping caul strips with shallow dados notched out to slip over the protruding fingers, otherwise it's hard to get clamp pressure right at the corners.
If you build it he will come.
Edited 5/26/2008 7:52 am ET by douglas2cats
Thanks. I think this is similar to what Christian Becksvoort does when he glues up dovetail cases--he partially assembles the case--just gets the dovetails started and then applies the glue. I will also go easier on the glue this time. Tom"Notice that at no time do my fingers leave my hand"
