Hi again, I am starting to turn a bowl as my first turing and was wondered if I can change speeds on my OLD Rockwell lathe by swiching the vbelt from the two exposed 4 belt pulleys on the motor and head peice.
David Churnega from Cleveland, Ohio
Absolutely, Just remember bowls like to run slow.
Start by using the largest pulley on the head stock to get the slowest speed. Spin the stock by hand first(no power) first to check balance and adjust as needed. I always bandsaw my bowl stock round before turning, that helps balance a lot.
Come out to the Eagle America, Woodworkers Outlet Store in Chardon, OH. and I'll give you a few lessons, I work part time, so call ahead and ask for Bruce. 440-286-7435
Bruce S.
