The subject says it all. A swift move in the shop landed two drops of 3-in-1 oil on the oak mailbox waiting for finishing. They’ve since bled along the grain into an area much bigger than the original drops.
So, what if anything can I do to minimize any effect this might have on any finish? I was considering gel stain with a coat of uv poly.
Any suggestions?
Thanks!
Adam
Fine Woodworking Recommended Products
Jet JWJ-8HH Helical Head 8-In. Jointer
This machine joints a very good surface, with a fence that is flat and smooth-moving. The fence is easy to set to 90°, and it stayed that way. The 90° stop was also easy to set and reliable. The start and stop buttons can be installed above or below the infeed table.
Delta 22-555 Planer
Knife changes on this planer were easy enough, except that you need an Allen wrench to open the dust cover and gain access to the knives, and it’s not the same size as the wrench used to loosen the screws that secure the knives. The 2-1/2-in.-dia. dust port can be reversed for use on either side of the machine. Two material rollers on top of the machine aid with transferring stock from the outfeed side back to the infeed side. Finally, there is no gauge that indicates how much material you’re about to remove, a convenience that three other planers also lack.
Blackwing Pencils
If you've listened to Shop Talk Live, you've heard them talk more about these pencils than you could possibly imagine.
Grout float
The red foam on these grout floats grip well to wood, and the large handle keeps your hands safely away from bits and blades.
Rikon 60‑101
The Rikon’s power and capacity are comparable to the other smaller models, but a few issues held it back. Because the chip bag hangs a bit loosely on the canister, it tends to slip off during changes. On the plus side, it’s the only small collector with a 5-in.-dia. intake, so if you discard the Y-junction with the 4-in. ports, and run a 5-in. hose closer to your machines, you’ll add efficiency.
Try using acetone to stop the progression. It may also help remove it but will take a few tries. Remember to use it in a well ventilated area!!!
Dampening a cloth with acetone or some other solvent and pressing it against the wood might "wick" out the oil - like getting a grease spot off clothes.Better try it on a piece of scrap first in case it helps spread the damage instead.
I'd just coat the whole thing in 3-in-1, call it a hand-rubbed oil finish, and move on to the next project!
Gatordoc
>just coat the whole thing in 3-in-1, call it a hand-rubbed oil finish, and move on to the next projectSweet !
Edited 11/11/2008 1:17 am by roc
And... it will be waterproof!
As they say, "Spew!" I like the way you think ;-)
I do know someone who, after careful research (one party to this is a PhD ME) used new Quaker State 10W-40 on the shingles of the one's ocean side house! This was at least 20 years ago, I don't know whether the performance/cost equation would balance out differently now.
I personally have never tried it but my good friend who is a gunsmith had showed me a trick for removing oil from wood (in this case - wooden stock for guns and rifles). He used a strong solution of disolved t.s.p. with water and a hot steam iron with a cloth soaked in the solution. Shortly after he 'ironed out' the oil from the wood, one would never have known there was any oil on it in the first place. Try it on a scrap piece first. After all... heat and water on a wood project sounds like disaster!
"I personally have never tried it but my good friend who is a gunsmith had showed me a trick for removing oil from wood (in this case - wooden stock for guns and rifles). He used a strong solution of disolved t.s.p. with water and a hot steam iron with a cloth soaked in the solution. Shortly after he 'ironed out' the oil from the wood, one would never have known there was any oil on it in the first place. Try it on a scrap piece first. After all... heat and water on a wood project sounds like disaster!"
Many Moons ago in my college days I was a house painter in the summer time. We used TSP to kill mildew on the siding before painting and its great stuff, but be careful with it it will burn you. Be sure to use rubber gloves rated for chemical use. I was working a job with lots of trees close to the house and was on a ladder cleaning the soffet (pardon the sp) and some of the stuff ran down the gloves on to my forearms and before I realized it it had left a nasty little chemical burn. I still keep a box around for tough cleanings and its great for grease spots on concreate. Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
Dear A,
Sham-wow???
There is a special absorbent material, such as "oil zorb" http://www.boatersworld.com/product/177870060.htm that are cheap, effective and will only absorb oil. I would suggest rubbing the oak or applying the material on the oak and laying some weight on and see if it will wick up.
Best,
John'
