A challenging project, not only to me, (Im not a woodworker but an interior designer sortof) but I need your help
There is a bookcase, which I have hired a fairly capable handy guy to help me build, here is the pic above:
What I would like to do is get some ideas on how I can make this bookcase happen without having the wood (either horizontally or vertically touch the ground) , in other words suspended shelving with all these curves.
Im planning to paint the whole thing white once Im done with the construction of it.
Between my handy man and myself, he is claiming that it is going to take at least 8 days of 9 hours a day to build this… (and be quite expensive too)
How to I create some “floating shelves”?? what is the process? and the hardware that I need/??
thanks in advance to everyone who is able to help me conceptualize this project and bring it to reality.
Thanks!
Kimberley
why not hire
someone who knows what they are doing rather than a handyman
ron
ThankS Ron for answering my question. You're right, I really do need to hire a woodworking person however Ive caculated that it will cost me $3000.00 with a handyman versus 10,000 with a carpenter and I dont have the money to do that so .....
Talk to a commercial cabinet shop that has a CNC router. That's how the original pieces were made.
I don't think that you will be able to "float" the shelves off the wall. Too much weight.
Good luck with the project!
Rick W
cabinetmaker
the fact that you are asking tells me your "handyman" needs to stick to leaky faucets & squeaky doors. hire a specialist. we put alot of blood, sweat, tears, & money into this trade.
Don't Waste Your Money
Don't waste time and money trying to have anyone less than a pro shop pull this off, it's harder than it looks. It's going to take a lot longer than he's quoting you assuming the project is the same size and scale, if it's even possible. Without a CNC router you're going to be freehanding all those curves with a jigsaw, smoothing and fairing them, edgebanding them, etc. A LOT of template and design work goes into something like that as well. I do, however, think it would be possible to raise it off the ground if you integrated nailer strips into the back of the case that were properly reinforced and mounted it to pretty much every stud on that wall at multiple levels. Just be sure and reinforce the structure as well to compensate. Good luck, it's a cool project if you can pull it off.
Thank you AutumnWoods. You're correct! This is a cool project..... I just wish I had the money to hire the real professionals. Hope it turns out ok
I'm going to pile on with the rest who says a project of this ilk calls for a full fledged pro shop. But be prepared for the sticker shock.
Kimberly,
The others are overthinking this. If you go to Ikea or better yet, Wal-Mart, and buy three or four of those bookcases that are made of pressboard, and float them in a swimming pool for a week or so, you can achieve this effect without all that CNC technology.
Nice One
:-) I think that might actually work... I see an article in the future of FWW on the "Float and Bloat" technique.
Sortof Designer ?
Kimberley ,
Imagine a large wall cabinet or bookcase that does not touch the floor .
With a full back or backs and screw rails across the back they can be fastened to the wall without touching the floor .
Often on floating vanities or other largish wall hung cabinets that are near the floor we run a wood cleat or in your case I would run a continuous base mold to support the back end and weight of the units .Steel angle iron can also be used .
In truth that is a pretty tricky job to bid for most of us so maybe the handy Man knows that and is going the time and material route .He can't get hurt financially but if you trust him and he is hardworking all will be well .
The time estimate is hard to judge , partly it depends on the experience and equipment used .
The term handy man may not be a fair one to your man , but to many of us the term means he will do it cheaper and not as well in some not all cases he may be a divinely talented maker .
good luck let us know how it turns out
regards dusty,boxmaker
Kimberly,
I am not a perfeshkinol, but I think it is quite possible to float this thing. I would build and install in sections using french cleats. Carefully done, it should go up and slip together without much problem. Obviously, I don't have the years of experience of the other guys, but if you plan carefully, and if your handyman is as capable as you seem to think, I don't see any reason it can't be done. Mind, there WILL be a few bumps in the road, but plan for that, have a bottle of Diet Cherry Doctor Pepper to make things go more smoothly, and work your way through it. Make certain you can communicate with the handyman and he with you. If everyone listened to everyone who said something can't be done, Livingstone would have never found Stanley.
Steve
