I found a 14″ DeWalt Radial arm saw built in 1952 , has a 3 hp motor wired 220 volt, seem to run ok. This is a comercial saw with a steel table, very heavy! Everything seems to work but needs cleaned up and lubed . The saw seems to be tight with no excess movement. My question is what is a good price to pay? Thanks John Tolbert
Model #?
You can't wait for inspiration. You have to go after it with a club.
Jack London
Model# GR Ser.#110667
That's a great machine and in my opinion if it's in good shape worth every penny of $500.
You can't wait for inspiration. You have to go after it with a club. Jack London
Here's a link to the manual courtesy of OWWM.
Thanks and thanks for the manual link. I just bought the saw for $125 no blade. will look for a good blade tomorrow.
john
That's a steal! You will be tickled with that saw. Accurate as the day is long and will work for hours on end without a whimper.
There is one GR model listed at http://www.OWWM.com in the pictures section. FYI The GR is set up to run 12" or 14" blades.
Bruce S.
Well let us see some pictures then.
Does it look like this one which I recently did some work on? You can see the serial numbers and that this one is 3 phase.
That's a really nice saw. I own a light weight DeWalt radial, not an accurate saw!
I got it used from a contractor who's idea of maintenance and accuracy were not what I consider accurate so after much fixing up and frustration I realized its not me its the saw.
I no longer use the saw so it just collects dust (what a shame!)
Chaim
Chaim,
the one I pictured above is a medium industrial saw, or what I would call a "proper saw", and they are fine machines if cleaned up and re-adjusted.
Those light weight diy type saws that you mention are the very ones that have given radial saws a bad name, with inbuilt faults. They are also dangerous . Best left alone, or converted into something benign such as a buffing head or grinding head.Philip Marcou
I couldn't agree more!
that's why I bought other tools, to replace the radial arm saw. besides it being inaccurate your right its also dangerous.
Chaim
