Hi!
I am new to this board. I have some air dried red oak, 5/4 @ 12%, that has some worm holes and I have seen some saw dust from these holes. My question is how do I get rid of these worms without putting the wood into a kiln?
Any info will help!
Thanks John.
Fine Woodworking Recommended Products
Amana 46577 1/4-in. Up-Cut Spiral Bit
Diameter: 1/4
Cutting Height: 1-1/2
Overall Length (L): 3
Surface Coating: Spektra
Triton TA1200BS Belt Sander
Weight: 10.6 lb. Amps: 10 Variable speed: Yes Belt alignment: Excellent Material removal rate: Good Sanding flatness: Excellent Shaping/scribing: Very good Handling on side: Good Dust collection with hose: Very good
Foam Brushes
Foam brushes are great for applying a variety of stains and finishes, and the 2" wide brush is the most versatile. Comes in a pack of 48.
Tried & True Original
For the ultimate warmth, glow, and clarity, in a hard-wax oil, Adam Godet recommends Tried & True Original. To get there, however, you’ll need to buff it between coats.
Joinery, Joists and Gender: A History of Woodworking for the 21st Century by Deirdre Visser
Part history and part survey of contemporary craft, Deirdre Visser’s Joinery, Joists and Gender: A History of Woodworking for the 21st Century (2022, Routledge) weaves the stories of historic and contemporary makers into the first collective history of women and non-binary makers in the field of wood.
Hello,
Do a search on powder post beetle in the advanced search section. There is a lot of info on them. Powder post beetles have very small holes. If the holes are about 3/8", they are a different type of beetle. I have been told that the large ones are tasty if fried, by my friends that went to survival training.
Thanks Chuck,
I will start here looking for powder post beetels
John
If the final demensions of the pieces you will build with this wood are such that they will fit into you kitchen oven, then heat the oven to ~180 and put them in for 1-2 hrs. I've read about this technique and tried it with good success.
I've had termites in old walnut logs that I've cut up - I've seen the tunnels, the frass (sawdust/poop combo), and the termites, sometimes only a fraction of a termite hanging out of the saw cut!
I've gotten rid of the termites by freezing for a few days, keeping at room temp or a week or two, then freezing again. Freezing just isn't very good for wet biological tissues.
Never tried it with beetles. Try it with a scarp that you're sure has beetles in it and put the scrap in a mayo jar with little holes in the lid during the "warm 'em up" period. After a few cycles, let us know if you see any frass. The wormy wood can add interest to your work or you can fill the holes with whittled tapered sticks hammered in and cut off at the surface (etc).
