I just purchased a 9″ vise from rockler and upon opening the box at home I discovered that the faces of the vise do not close evenly. The top of the vise faces come in contact and the bottom of the face has approx. 1/8″ gap…giving unequal pressure to anything I am planing etc…Upon looking at the description of the tool online they actually describe a “toe in” on purpose. this doesnt seem appropriate to have equal forces to secure the piece of wood!? This is my first wood vise, is this an issue before I mount it on my bench.
thanks Willy
It is exactly what you want. Toe-in compensates for the fact that the screw is at the bottom of the vice, without it when you tightened it on a work piece it would spread on the top.
when I screw down the vise I cant make the bottom, touch...still nothing to worry about.
Install tapered wood jaw liners.
Once you put a piece of wood between the jaws, the vise will rack a little and grab the wood evenly across the jaw.Chris @ http://www.flairwoodwork.spaces.live.com(soon to be http://www.flairwoodworks.com)
It should be fine. It will also have less toe as you use it and it wears in. I line my vise (a Yost paternmakers that also has about 3/32" of toe) with leather glued in with contact cement. My old Record 52 1/2 has the same treatment.
Yep ! I like bass wood or lime. You can even add leather to the wood jaws to make a great anti mar gripping surface.
One way you could make the jaws parallel if you want to try that is put the wood jaws in the vice and close the jaws. Then using a big hand saw cut down the seam between the jaws this will make the jaws parallel.
I agree the taper is normal and desirable though a full eighth of an inch is a lot.
roc
Edited 2/10/2009 12:19 am by roc
