I am a novice turner. I have turned some wood that seems to be impossible to sand completely smoothly. The wood is purpleheart, blackwood, and buckeye burl. While the other wood — maple, cocobola, ash, magnolia, hickory, sycamore, rosewood, mesquite, to name a few — I turn can be sanded to a completely smooth state, these three woods pit as I sand them. If I sand out the pitting in one place, it appears in another place (I sand while the lathe is turning at low speed). Am I doing something wrong or is this just a property of the wood? Is there anything I can do to overcome the problem? Is there a particular kind of finish I should use to compensate for the problem?
Further, the buckeye burl, which is very light in weight, retains the sawdust in the grain as it’s sanded. I’ve tried blowing it out with compressed air or removing it with tack cloth, but neither gets even most of it, much less all of it. How do I get the sawdust out so the wood sheen won’t appear dull? Is this a finishing problem as well?
I am NOT a Turner.. However I use purpleheart all the time. Yes! the grain will pull out ('pit?) I have never had much of a problem sanding it when using fine grits. Metal Scraper works the best for me. Not sure how it works on 'BIG' a lathe but it will also shatter! At least with a router when the cut is a 'weeee' bit deep.
I have a Mini lathe and uses Purpleheart for knobs and such. I 'spin' it at a slow speed and 'wet' sand it with whatever oil I am using. HOWEVER. I never go for a gloss finish so may not be appropriate for your question.
If I want a 'gloss' I wax it with a high speed linen buffing wheel!
Sure your standards are a bit higher than mine!
