Hello – please help! I am a mostly hand-tool woodworker with modest resources – these include working in a thin-walled garden shed with a propane heater going when I’m in there in the Seattle winter. In general, I work on projects from wood that is stored year-round in the shed, finish them usually with polyurethane, and then move the completed furniture into our (centrally-heated) house for use. I have noticed that joints which were planed/sanded flush, and finished to a smooth surface appear to shrink across the grain after a few weeks inside to the point that the surface of the joint is no longer flush, and a ‘step’ can easily be felt between individual components. I assume this must mean some partial fracture of the glue line, and compromise of the joint. In one case a lap joint that was precisely cut, clamped and glued, and finished with polyurethane, began to frankly split. I assume all this has to do with moving wood from a relatively wet environment (my shed) to a dry one (our house), with consequent drying out of the wood, despite finishing all surfaces with relatively impermeable polyurethane. How do I deal with this depressing problem without building a climate-controlled workshop?? Should I keep my wood in the house and only work it in the shed? Would a dehumidifier help? There must be plenty of others in my situation working in a shed or garage without heat. Thanks so much
A,
Thank you for your question.
As you have pointed out, you are dealing with humidity change.
One thing you can do is make your joints really tight. When you take the furniture indoors in the dry heat, the wood's contraction will not be as noticeable.
You can also get a dehumidifier for your shop to help the wood transition into your house better.
This article may help with you with this issue:
http://www.taunton.com/finewoodworking/FWNPDF/011165044.pdf
Sincerely,
Gerald La Starza
Fine Woodworking
Thanks for your help.
