I’m building an oak mantel above a fireplace.
Is there anything special I need to do to the wood to protect the underside or deflect the heat?
Local codes will probably indicate miniumum distance (clearances) from the opening. Call the local building inspector, or perhaps the fire department could give you the values.
Tell the clients to keep the fire in the fire box, and not on the hearth or mantel.
The US national building codes say that within 12" of the fireplace opening, wood cannot protrude more than 1/8" for each inch away from the opening. For instance, 6" away from the opening, wood can protrude 6/8" forward from the opening. Beyond 12", you can do anything. Most local codes adopt the national code rules.
Thanks Jamie, that's exactly what I was looking for.
Where do you find this type of information? I was doing google searches and could not find that.
