Sir: I have some salvaged logs from my arborist and from by back yard, redwood, beech, pecan, apple, etc. I want to use this wood for turning bowls and other turning projects. If using it for bowls I would like to take a 12 inch cross cut then split that for two bowl blanks. With this 12 inch blank how large of a bowl will I get? Or if I wanted a 12 inch bowl how long of a log should I cut off of the initial log? I am a novice at turning and have read a few books on turning but no one ever answered this question. Thanks, MH.
MH,
You've got the right idea, but you've got the details slightly wrong.
Measure the diameter of the log and then cut off a piece of the log as long as the diameter. For example: if the log was 10 inches across the end, you would cut off a 10 inch piece of the log which would give you two blanks that would allow you to make 10 inch diameter bowls about 4 inches deep after flattening the side for mounting on a faceplate.
For a 12 inch diameter bowl you will need a log at least 12 inches in diameter, but preferably a bit larger to make up for the thickness of the bark and some shaping of the outside of the bowl.
You've got a nice assortment of wood species to choose from.
John White
Edited 4/10/2008 4:29 pm ET by JohnWW
Thank you very much, MH.
