I made a three piece computer station one piece at a time I used Minwax Winter White Pastel Stain. I covered it with Minwax Water Based Poly. One section turned darker than the other two. Other than stripping the whole thing, is their anything I can cover it with like the Minwax stain and Poly to make it all one color?
Will
I think your options are limited. It seems to me that you could either strip the one dark piece and redo it. Or you could paint the whole thing. Reapplying more stain and poly on top of the existing finish wouldn't look the same even if it would work... which it probably wouldn't.
Kevin
All,
Options are limited, but before painting it why not sand with 220/320 and apply a good gel stain to see if you can even the finish. I previously had a similar problem and was able to achieve a reasonable match using this approach.
Doug
