I’ve been trying to find out the best sandpaper to use. I’ve been buying the cheap stuff and now realize I cannot afford this – too much grit that comes off, too much sawdust loading up the paper. I’ve looked a bit on this site and found one article that has a lot of info on types, how it is constructed, etc. but does not give a recommendation. I need the sandpaper for normal shop use, that is smoothing, finishing furniture and turning projects.
Any recommendations on which paper is best as well as best place to buy it would be appreciated.
John
My favorite is . . .
. . . no longer available - Norton Garnet paper. Fortunately, I still have a good supply.
Among the current abrasives, Norton 3X (aluminum oxide) appears to be favored by suppliers, and is available from numerous retailers, including Rockler, Woodcraft, Tools for Working Wood, et al. Norton, founded in 1885, has been at this for a while.
No Garnet ?
That's terrible news ! It's basically the only paper I use. I called Norton and stock is still available from them until they run out.
Telephone: 254-918-2306
SA
re: Terrible News
That's what I thought when I went to the Norton site to update my product awareness. Good to know that they still have some old-new stock on hand, though.
After 150 grit, I usually shift to wet/dry paper in 220 grit and higher, depending on what I'm doing (e.g. levelling a finish for subsequent coats).
I've often wondered about diamond abrasives, but I suppose the coarser grits would be pretty expensive. ;-)
Sandpaper
I use Klingspor stuff, as I am satisfied with the quality. Great selection and service, too.
Best wishes,
Metod
Lathe paper
Well my favorite for use on the lathe is Mirka's abranet. It does not get hot at all and stays pretty cool.
Mirka's
Bruce - why do you need sand paper at the lathe - are you starting with a 40 grit after your turning is finished ?
Just Kidding ! Don't get upset but try to learn some new sharping techniques ! - Just Kidding !
SA
which sandpaper is best.
When talking about sandpaper "grit" is a reference to the number of abrasive particles per inch of sandpaper. The lower the grit the rougher the sandpaper and conversely, the higher the grit number the smoother the sandpaper.
