I am restoring a Victorian Walnut buffett – I need to glue some parts together – what glue would you recommend that can be bought over the counter?
Most will work, even the simplest, all the way from Elmers to Titebond.
I always use Elmers white unless I need waterproof then I go to Tite Bond 111. Both have long set up times for the frequent mistakes i seem to have to correct. And Elmers white is not expensiveWicked Decent Woodworks
(oldest woodworking shop in NH)
Rochester NH
" If the women dont find you handsome, they should at least find you handy........yessa!"
Considering that it is an antique, you might use liquid hide glue. Available at most hardware stores. Just check the expiration date to be sure it is still good.
Tightbond III will give you more "open time" than the other usualy suspects at the hardware store, and if you happen to live in a cold climate, will be workable at colder temps next winter than the others.
I like the suggestion to use hide glue, and 'twere it me, that's probably what I'd do, but it's very difficult to find fresh stuff in the stores. Perhaps you have a Woodcraft or Rockler nearby? They'd have flakes even if they don't have fresh liquid.
If you're restoring then that means to me it's either/or old or an antique. Either way, I'd recommend hide glue.
