What’s the best way to get a silver, weathered looking finish? I want to use a cedar to make a piece of indoor furniture.
Start Your Free Trial
Randy I too have tried to get the weathered silvery look that your looking for and the only thing I have been able to come up with is allowing mother nature to do the job. I have done this very thing and it does not take as long as you might think. What I did was stand the cedar boards upright facing the sun during the heat of the day and left them there and I watered them daily I know it sounds far fetched but it works. The watering and drying and the sun is what cases the effect you are looking for. Now it took me about a good month to get some nice silvery color but I also live in Texas so I have alot of heat and sunshine. I hope this helps out. I know that you are looking for age in a bottle I don't think you are going to find much on that because cedar dose not have any tannins in it.
RAND, move to Cape Cod Massachusetts,
Salt air (FROM THE OCEAN)
Hot air( FROM THE KENNEDY's)
Steinmetz.
Randy,
When we built our home we wanted the Alaskan cedar to look wheathered and gray quickly...they used a bleaching stain on the house...I have no idea of the brand name. However, maybe you can experiment with a bleach wash?
Edited 8/15/2004 8:18 pm ET by BG
I have zero expertise on this question, but I think BG may have suggested another direction you might want to check out . I have never used the products, but I am almost certain I have seen stuff on the shelves of a paint store as I whipped by. That is, products designed to give cedar a "weathered" appearance.
EDIT: Personally, if I had the time and the right climatic conditions, I would certainly try the natural approach outlined by our texas contributor.
Edited 8/18/2004 12:52 pm ET by nikkiwood
I have tried Minwax pickeling stain (I found it on clearance). It wasn't great for me, but it's worth a test. It does gray bare wood. Todd
You've gotten some good suggestions on how to color the wood. To get a weathered texture, I've used two different methods:
1. A light sandblast of everything but the joints. I put two layers of duct tape over the areas I don't want to texture.
2. Wire brushing along the grain will also give a weathered texture.
The weathered texture comes from wearing down the softer part of the grain leaving the harder parts proud of the surface.
FWW had in article in Issue 50 (around 1985) by Jim Cummins on a driftwood finish, which sounds kind of what you might want.
