A Client has asked me to refinish a dining table and she wants a high gloss finish. I have refinished two leafs as a test and used, as a finish, Flecto Varathane Crystal Clear Waterborne Gloss non yellowing. It is water clean up and is nice to apply and has a very high gloss. Will this product stand up to dining table use? Any problems with specific stains such as water or wine?
Willy,
That finish (waterborne finishes in general) are among the toughest and most resilient finishes available. Be aware that waterborne finishes impart no colour - none of the warmth expected from other types of finishes. Depending on the wood it is used on, it can result in a very cold looking finish, which I don't like. Experiment first on a scrap. If you find it too cold, start the finishing process with a coat of shellac, then proceed with the waterborne stuff.
I'm heading to your province in 8 weeks - - - So it's o.k. to apply shellac and then a water based finish? It must be or you wouldn't have suggested it.
Only use dewaxed shellac under a water based finish. If it is just a seal coat with minimal color change then Zinsser Bullseye SealCoat is a good choice. For other color choices you may need to buy dewaxed shellac flakes and mix your own.
Willy,Yes it works. The dewaxed part is important if your top coat is not shellac also (which it isn't), which will redissolve the first coat.Chris @ http://www.flairwoodwork.spaces.live.com
If you want a surface to remain good looking for a long period, there is nothing like coasters, placemats and trivets. A waterborne acrylic finish won't be quite as protective as an oil based varnish or a two part lacquer but it will last forever if it is taken care of.
Hello Willy,
I suggest that you check out the water based finishes by Target. They are the best water based finishes on the market IMHO. I highly recommend their Oxford EM8000 conversion varnish. It is very tough and imparts a very slight color nearly identical to an oil based varnish.
Bob, Tupper lake, NY
