I will be visiting Manhattan for 8 days in a few weeks. Any recommendations for woodwork places to visit? galleries of fine furniture or not-to-be-missed tool places?
Robin L
Fine Woodworking Recommended Products
Double Sided Tape
A thin woven core makes XFasten tape strong yet not too thick (0.008 in.), and helps it hold powerfully without being difficult to peel off.
Bessey EKH Trigger Clamps
Bessey EKH series quick-release trigger-style clamps are simple to use and maintain consistent pressure. Trigger clamps that perform the way you've always wished they would!
Skilsaw SPT88-01 Miter Saw
This saw performs as well as the others, but its price and inconveniences make it hard to recommend. As far as the positives go, the handle is comfortable to grip. In use, its power switch works for both righties and lefties. However, other ergonomics are OK at best. It’s also another saw with the bevel lock at the back, meaning it’s a reach to get to. The tool has good bevel and miter range. It’s the only worm-drive saw, but I did not notice any difference in cut. The saw cannot sit flush to a wall.
Bora NGX Clamp Edge System
The NGX Clamp Edge System from Bora promises to deliver all the functionality of a proper track saw using the garden-variety circular saw you already own. The five-piece Deluxe set includes the sliding saw plate, the 50-in. Clamp Edge track (with built-in edge clamp), a 50-in. extension track, two specialty clamps for angled cuts, and zero-clearance plastic strips for both tracks.
Rockler Dust Right 1250 CFM
The big motor on this collector left the chamber under my jointer very clean. You’ll need help to get this heavy unit onto its bracket, but if you’re looking for a central dust collector that won’t gobble floor space, this may be the unit for you. Strangely, this huge unit comes with the smallest plastic chip bag, but you can replace that with a taller one from Rockler.
Certainly don't miss the American Crafts Museum ( http://www.americancraftmuseum.org/ ) in midtown. Also, the Cooper Hewitt may have some furniture design objects on display. Even if it doesn't it's still a great small museum (Smithsonian's NYC Design museum - http://www.si.edu/ndm/ )
Also, the John Nelder Gallery shows some of the highest quality studio art furniture by a good variety of artists ( http://www.johnelder.com/ ).
Years ago I went to Garrett Wade, but the show room at the time was about 200 sq.ft. and not very exciting. It might have changed, but I think the address is the same, so I doubt it.
And don't forget burgers and ribs at Virgil's (I think on 44th, maybe 45th, a half block east of Broadway - Times Square, near the ABC studio)!
Have fun!
Seth
*Try the Metropolitan Museum especially its American Decorative Arts department. There's also a gallery that shows the the development of style in furniture and other artifacts that's tucked away in a corner somewhere. Be prepared to spend all day there.
