I have a counter top that is 25inches by 130inches long, what is the best way to veneer the top, glue to use,and etc. I can seem it in two places that would not look bad. Does anyone Know if I can do it in one piece. I used veneer ply and the finish that was applied made the veneer delaminate in many places. Now I have to fabricate the top again, Just looking for some advice I am going to work on it this weekend. The jobs draging on and customer has been very patient, When he hears this I don’t think he’ll be too happy. Anyone have any answers sooooooon.
Hate pressure, LMC
I would use mdf instead of plywood.Smoother and won't delamaminate.You need a glue that does not creep, hot hide glue is what I would use.You can apply the glue, lay the veneer on and iron the veneer down.Do both sides,underside can be a cheaper ( poplar) veneer.There are other glues you can use,make sure they do not creep.White and yellow glues are not suitable for large veneers,seams will open up after a period of time.You can do it in one piece if the veneer is 25" or more wide and 130" long.You can trim the eges with a laminate trimmer or router,use a sharp bearing bit.
mike
Mike, I'm going to finish the top using polyester. will this be a problem? will this finish activate the hot hide glue? Where can you get the long veneer?
-Lou
Lou. I'm not familiar with polyester,do you mean polyurethane? The latter is a type of varnish, varnish will not cause a problem. Do a google search for veneer suppliers.I'm sure you can get veneer in the length you need.There is a glue for veneer called FSV, Never used it,but I understand it is a good product and does not require heating it.
mike
Mike, Polyester is a high build 2-part finish ( thick crystal clear finish) very durable and used on bar tops.
-Lou
