My first big project; perhaps too ambitious, but I want to try it. I purchased plans for a Morris chair from FWW. The instructions tell me to use 1/8 inch veneer around a core for the front and back legs. That means a miter joint longways on each of the sides of the veneer? That’s how I picture it, but how do I cut a miter joint that will match all the way up and down a twenty some inch leg on 1/8 inch material? I believe I can cut the veneer; it may end up a little more than 1/8, I can make up for the width by changing the dimmension of the core. It will be as close to 1/8 as I can make it. I have a bandsaw, jointer and planer.
You already posted this question: 41606.1
And you got a reply from Robert W Lang, senior editor at Popular Woodworking, author of several books and articles on Arts & Crafts furniture, and an acknowledged expert on the topic.
Bottom line: You're making this much more complicated than it really is. Follow Bob's advice. He even illustrates it in some of his articles/books. To see the technique in action, buy, beg, borrow or steal a copy of Arts & Crafts Furniture Projects and look at pages 75, 96 and 132. For an alternative technique for making Stickley-style legs, see the photo on page 18 and the sidebar on page 170.
The veneer is only so you'll have quartersawn material showing on all four faces. Frankly, for my first chair I wouldn't worry about it.
I always thought this little manoeuvre was a bit disingenuous given the ethic of the A&C movement. Let the wood be the wood. Quartersawn Oak does not show ray flecks (flakes) on all four faces and edges of a board. You could also simply use flatsawn material and avoid the matter altogether.
Mahogany was also used though less commonly than Oak, fwiw.
Edited 5/8/2008 12:26 pm ET by TaunTonMacoute
