Variable Speed RO Sander?
Hi All,
Was hoping to gather some opinions as to whether or not it is worth paying the extra money for a variable speed random orbit sander, or can I get away with (meaning will i regret) a lower priced single speed unit?
For what it is worth, I work mostly birch and maple and finish sanding is always done by hand. I remove machine marks with a card scraper and a handplane most of the time.
Any opinions would be a great help
-pjw
Edited 1/6/2008 12:04 am ET by philjohnwilliams
Phil,
Good question - it made me stop and think. I bought a VS model because it was a great deal. I have only ever used full speed. Slow speed is recommended for buffing. It's probably also good if you want to use it to sand between coats, though I would hand sand. The manual for my Makita 5" VS ROS states that extended use at a lower speed will cause the motor to burn out prematurely. I don't think VS is worth any extra expense.
Chris @ flairwoodworks
I also wondered about the usefullness of variable speed on an ROS, then used one at a buddies shop. Shortly I had my own from Bosch (link to my review of it below) and I have been a faithfull user ever since.
Being able to vary speed as well as grit makes this an even more versatile tool. I am able to get a very smooth finish without other tools on most projects and reach that point much quicker. In addition to the grits and variable speed , the amount of pressure applied to the sander itself further enhances how quickly it removes wood or how smooth (and scratch-free) the surface is.
http://www.newwoodworker.com/reviews/b1295DVSrvu.html
Tom Hintz
Because there is always more to learn!
I've had a Porter Cable 333VS for about five years. Most of the time (probably more than 95%), I use it at full speed. But I do use it at reduced speed when I need to be especially careful, such as when sanding a thin veneer with fine grit.
So, you want to put more machine marks on your work? You just aren't sure if you should have a variety of speeds to do it with? I'm just pulling your leg, Phil. Or am I?
the way I figure it the more machine marks I have the more time I get to spend with the plane and scraper :)
-pjw
pjw:
It depends upon how you use it. I find the variable speed to be very useful for sanding between finish coats, where I use the slowest speed. As another poster said, it is very useful to be able to vary the grit and the speed.
I couldn't imagine life without the variable speed.
Hastings
Hastings,
Do you really need a power sander to sand between coats? Hand sanding is usually quicker and safer, I find.Chris @ flairwoodworks
I don't use the ROS between finish coats, but I do sometimes use it with Abralon pads for final rubbing out.
Flair:"Do you really need a power sander to sand between coats?" — Probably not, but because of the slow speed and integrated dust collection, I find it far more pleasant, particularly when there is quite a large, flat surface area."Hand sanding is usually quicker and safer, I find." Me too! But I've become quite proficient in not sanding through.Hastings
Regarding the original questions, yes, I have a VS ROS (the Rigid 6" that was made for them by Metabl) and frequently vary the speed, depending on what I'm sanding (thin veneer isn't something you want to sand at a high speed, yet the initial sanding of a panel can readily be done at a higher speed). If I'm polishing a finished surface, the VS feature is indespensible. As regards power sanding between coats of finish, if the piece is large, I will almost always reach for the sander, as I can power sand it much faster than by hand.Marty from Ottawa
From what I gather, it would seem to me that the VS is useful if sanding veneer or maybe if you use it to sand betwen coats when finishing. If I do neither of these, then is it still worth my money?
-pjw
