I’m thinking of building a vacuum press from the plans found at www.joewoodworker.com in the near future. I’m leaning toward the venturi system so I can use my compressor. The parts and prices are so reasonable, I might just buy the kit of parts and put it together. Don’t know much about the vacuum press business and vacuum bags. Any experiences or inputs would be much appreciated. Love to see one of these in action. I’m in North Carolina.
Thank you ahead of time
I built the venturi kit from joe. It was pretty straightforward, and took only about an hour. I purchased the large bag 4x8 and the pump works very well to evecuate the large area of the bag. I don't use it for bending to forms, just for pressing veneer to flat panels, but I am able to get a good amount of sustained pressure.
The only down is that I have a smaller compressor in the shop, so it tends to run fairly often when using the venturi pump. Not a big deal, except my compressor is LOUD.
I recommend purchasing the heavy-duty bag, as I believe that it 's worht the extra$ for the added thickness.
Peter
www.jpswoodworking.com
I too built the venturi kit from Joe Woodworker. As Peter stated, it went together quickly and without incident. I have only used it with a 4' x 4' bag for flat panels, but it works just fine, even with my cheapo HF compressor.
(If you find yourself in the Tampa area, stop by and take a look.)
Edited 7/21/2007 12:55 pm ET by DickL
I went the other route and bought this:
http://www.veneersupplies.com/product_info.php?cPath=60_64&products_id=248
I just finished pressing some panels with birds eye maple and anigre. This was the first time that I've used it and I'm satisfied with the results. The pumps keeps 23-24 lbs in a 4 X 4 heavy vinyl bag. It's a continuous run pump and is very quiet.
I have a hi-flow pump from vacu press (http://www.vacupress.com). It works very well. It will evacuate ####4' x 8' bag in less than 10 seconds.
Of course it really depends on what you want to do.
If you are pressing a lot of curves then the rapid evacuation is a plus. The pump is really quiet compared to my compressor. However the system was $1400.00 with a 4' x 8' poly bag.
If you are looking to experiment with vacuum pressing then I would either try the make your own route or go with a small continuous run pump for a few hundred bucks.
If you are going to spend some money then get a good bag. Makes a difference after doing a bit of pressing.
J.P.
I built one last year and purchased a 4'x4' bag (the higher quality one that they sell) and I use a 30 gallon compressor to run the system. It looks a bit like a high school science project, but it works great. I'd strongly recommend that you look into Darryl Kiel's videos, they are excellent:
http://vacupress.com/videos.htm
Cheers,
Michael
wondering who your source was for the kit you built??
it sounds like you built the compressor/venturi system. any second thoughts??
I have a large compressor that I feel that I should put to use rather than buy a vacuum pump. I could be discouraged with some inputs but it looks like I'll get the parts from veneersupplies.com(joe) and build a small system.
thanks for the words
dan
I purchased my kit from JoeWoodworker as well. As far as the compressor is concerned, you don't need a large capacity tank if you can adequately seal the bag....Cheers,Michael
Hi Danmart,
I do a lot of one-off and small runs using a vacuum bag in my shop.
I bought a used continous duty vacuum pump off E-Bay afew years ago,
about 100 bucks, hooked it up to a hour timer when glueing.
I use the 5mil vinyl you can buy at the hobby/craft/fabric stores for bags.
This vinyl is the clear stuff like Aunt Mildred used to use to keep the kids from
peanut and jelly sandwichs on her sofa. I get the tape from the glass store they
use on windshields for the multiple use bags, and the caulking on a roll for the
one-off bags.
For fast removal of air from a large bag, I use my shop-vac.
The vacuum bag method is one of those methods you start finding using all the
time.
Canoedog
I assembled my vacuum press from parts that I bought from Joe and an EBay Gast pump. I paid about $75 for the pump and about $75 for the parts. The plastic came from a local supplier.
Unless you make a huge bag, I really don’t think that you need a big pump. The one I have is rated about 1cfm, and will seal a bag in 30 sec or so. I have a hard time believing that 1-2 minutes makes that much of a difference, and once most of the air is out it’s just leakage.
The pump runs continuously, and I just bleed a little air to get the correct pressure. I did not make the slick and fancy closure Joe shows, just a couple of 1X2 wrapped around the open plastic and two or three clamps. Once you pump it down, the vacuum pressure hold the seal.
I did get the filter. The air in most shops is full of dust, and it will wreck a pump fairly quickly.
Frankly, this was a quick easy and useful project
Neil
