Greetings,
Can anyone give me a lead on quality plans for a child’s rocking motorcycle. I don’t typically get into this type of project but I have an urgent need to produce two of these projects for upcoming fundraisers. I would appreciate any info.
Thanks to all……
Here is a few. Did a google for wooden motorcycle rocker plans, and got serveral hits
http://www.woodcraftplans.com/ac882.htm
http://www.woodprojects.com/MH-W2530.htm
http://www.grizzly.com/products/H5497
http://store.workshopsupply.com/catalogue/product_info.php?currency=USD&osCsid=7e9dda67ed58474c7a2300230fd81ff3&products_id=869
Edited 5/1/2006 10:19 am ET by bones
many thanks, that certainly is above and beyond the call of duty, I'll check them out
No problem, hope one meets the fancy. Good luck.
try:
Somerset Publishing, Inc.
2110 Washington St. NE, Minneapolis, MN 55418
Plan # SOM-09802
I started one, had to bail out because of time constraints. You must have a spindle sander or drill press with sanding rollers to sand the 2" thick material!
The Plan is detailed, easy to follow.
Hope this helps.
thanks for the info,I'll check it out
