HI New Guy here, I have a unisaw which I have had for about 10 years. It has sat mostly idile for the last 3 with just some sporadic use. I recently noticed a crack in the cast inside. Not sure what the area is called so I attached a pic. So I have a couple questions to pose.
1) Has anyone ever seen this
2) is it easy to replace or should I have a tech do it.
3) would it be possible to use some type of glue or epoxy to fix it. (it seems to stay pretty well lined up most of the time)
Make sure it's realy a crack, but if it is, there aren't too many viable fixes. If it hasn't run too far down the back, you might be able to bore a stop hole. If you know someone who can braze it that might work but that part is available from Sawcenter or Delta so you'd probably best replace it.
Pete
