I am interested in building a sideboard and replicating some of the detail on the leg of an antique table. Can anyone tell me how the small beads are made that encircle the leg of this table? Picture attached.
masat,
Begin by turning a ring of semi-circular section where you want the string of beads to be. Then carve the beads using a gouge of the proper sweep to chop alternately straight down and at a slight angle, to delineate them. The waste between is removed with a small chisel or a shallow sweep (almost flat) "fishtail" gouge. Finish by modeling the beads to shape with an appropriate gouge, then sanding as necessary.
One other way is to use an ornamental turning lathe and a horizontal cutting frame.First the large bead would be turned then pearls cut on it using the frame.Easy if you have an ornamental lathe such as a Holtzappel. This will set you back almost as much as a house.There is one in the Smithsonian
I agree with your advise, but would warn that those balls must be done cautiously, they pop loose leasily.
They look very uniform and consistent. Could they be applied?
Drill evenly spaced holes while mounted on lathe, using index. Turn individual plugs and apply.
Frank
