What is your view on the differences between the glueline rip and WWII saw blades per your comment to chipsndust.
Thanks, Rick
Thanks, Rick
The overall difference is that one is a rip blade (Freud LM74, glue-line rip) and one is an "all purpose" blade (the Forrest Woodworker II). The LM74 has 30 teeth, the WWerII has 40, the hook angle is quite different (12° v. 20° for the WWerII). The tooth configuration is different -- the rip blade is a triple-chip grind, whereas the all-purpose blade has the traditional ATB (alternate top bevel). These are two totally different blades -- the Forrest is supposed to fit the "one blade does it all" dream, the Freud GLR is a rip blade for those who hope to skip the jointer process.
If one were to try and use one of these blades for the other's purpose(s), disappointment would ensure. Triple-chip grind emphasizes long-wearability (sorry, is that a word?), but isn't going to be your best choice for chip-free crosscuts <grin>. It'll last alot longer than an ATB blade, though, when used for ripping hardwood, and I suspect put less stress on the saw (a factor for those who're using 1.5HP motors).
The LM74 is stated to be best with woods <1" thick. For the thicker woods, the Freud line blades have fewer teeth (24 or 18) and a higher hook angle (20°).
My feed technique isn't so perfect that I don't get some burning periodically, so glue-line rip is of no interest to me. I use a 24T Diablo blade from Home Depot, it cuts great, and is kind to my old saw.
I was told by my tool supplier that the glueline blade was designed for larger more powerful saws. I have a dewalt 10" for job sites and he told me that saw is under powered for that blade. He sold me a thinner kerf rip blade from frued designed for smaller saws. that all being said the thinner kerf blade & the glueline both work very well in my saw, yes the saw works a little harder with the glueline but the results are very good.
have great day, Paul
The Diablo rip blade I use (Diablo is a Freud line) is a thin kerf blade and, yes, it's pretty easy on the saw. They also make TK blades in their industrial (LU) line, which may be what your tool guy sold you.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
