I have an old plane that my grandfather owned. I’m trying to identify it but I am having no luck. The only stamps I can find are “MADE IN USA”, “7” and a “5”. The link below has images and point out where the 7 and 5 are. The sole is 10” x 2 3/8”
Is this plane any good? The sole needs some flattening, but every thing else seems ok. Don’t know if I should set it on a shelf, or use it. Also, can you get good results with an old iron, or should I replace it? If so with what?
http://home.swbell.net/whaley20/plane/
Can't really see all to clearly, but it appears that the frog is stamped steel. The frog is the part of the plane under the blade. If this is the case, you are probably better off putting the planeup on the shelf as a rememberance of Gramps, and go lookng for a Stanley Bailey to start with.
If you can't tell the area I'm referring to, take another photo aiming from the rear of the plane to the area right ahead of the tote (rear handle). Then any of the guys out here with plane fettling experience can weigh in.
T.Z.
It seems pretty thick, but it does appear to be stamped. I've added some picks to the frog.
Any idea on the age of it?
Hard to say. Probably a post WWII era from the looks of the tote. As I said earlier, if it has a stamped frog, keep it as a fond family rememberance and look for a Stanley Bailey. The size of your plane is a smoother size, so if you want a duplicate, look for a #4. At flea markets they can be had for $10 or $15 and will have good enough "bones" to be a good user for you.
T.A.
Thanks for the info. It will go on the shelf as is, instead after spending a mess of time flattening and sanding off the patina.
http://www.hyperkitten.com/tools/stanley_bench_plane/dating/Here ya go...
Edited 10/25/2008 7:30 pm ET by Jimmy http://www.hyperkitten.com/tools/stanley_bench_plane/dating/ Try it again
Edited 10/25/2008 7:32 pm ET by Jimmy
thanks for the link, i'll be pouring over that "plane dating" site.
i've recently come into possession of a number of planes that i'd like to identify as best as i can, for re-sale in the future.
if anyone with a yahoo/flicker account cares to take a gander at photos i took this morning, you can see them at
http://www.flickr.com/photos/31785798@N04/
i've only just started trying to identify these items today. i didn't bother to post pictures of ones that i have identified.
thanks.
I have a Dunlap plane like yours on the shelf in my shop. Frankly, the plane isn't worth any effort to put it into use. Like yours, that plane has some sentimental value to me. It was given to me by a friend in his final days before cancer took him.
If you're interested in Stanleys, I assembled a huge chart of most known Stanley Bailey information. It's here: http://www.primeshop.com/access/woodwork/ - look for the link to "Stanley Plane Typing Megachart." Kudos and countless thanks to those whose hard work helped to get it usable.
