Hello, i am helping orphans in Guatemala build toy cars as part of an outreach program in their community. Painting toys is not a thing I’m used to on a large scale. I’ve seen some videos on Youtube of companies using large drums to paint small parts like wheels and heads, but I can’t find any info on what type of paint to use. Does anyone know any information on drum or tumble painting?
Additionally, is there any thoughts on dipping these small parts. My concern is getting them to dry without runs. Any help is GREATLY appreciated. I don’t want to submit them or myelf to the cost and fumes of spray paint! LOL
Thanks so much in advance,
Chad
How to start an international incident
I'd suggest reading up on the CPSC (Consumer Products Safety Commission) regulations for making toys in the U.S. Then, once completely discouraged, consider practical options. Although restrictions in Guatamala are probably non-existant, recommending something unsafe for so-called third-world children might get UN attention.
Toy Finishing
I have often used Mazola Corn Oil or Mineral Oil (Baby Oil) to finish toys. Both are safe for the children
Many Paint manufactures have started to provide the CPSC certifications for the paints and other finishes. Check out their web sites to get a copy of the certifications.
I don't have any info on mass painting by rolling parts in the paint. But I have had great success with mass coloring of parts like tires, axles, car bodies, etc using dye. Rite dye (that is regularly used for cloth) works very well. Mix up a gallon or two in a 5 gallon bucket, bump in the wood parts to be colored and let them soak until the color looks right on a test piece you pull out. Then just lay them out to dry.
After assembly, I have also dunked the entire toy in corn oil and then set them out to dry. You might use a little more oil this way, but it is a great time saver.
Hope this helps
Age restrictions
So, I guess the trick is to make wooden rattles and little cars for 13 year olds and older? ;-)
