Having just completed a new set of benchtops made from Australian Jarrah which were made in workshop and then setup in kitchen the problem I have is this, where I had to sand joints to butt them together I can’t seem to get the Danish oil finish to match. If viewed from a distance the join areas appear lighter than the rest, even after several coats. Is there a secret to touching up Danish Oil or do I have to rub back the whole job and start again.. and advice welcome..
Thanks in advance..
Dan
Is there any chance that your sanding could have burnished the surface so that it doesn't absorb? How big is the area you're trying to touch up?
Thanks for the reply, the area is about 450mm x 150 both sides of joint. To answer Alan's question also there was no glue applied. I sanded to 320 by hand but had to start with 120 to reduce lip of joint. I dont think that I sanded hard enough to burnish but I may have. As I am a novice in the use of Danish Oil perhaps you could advise if I have sanded to fine, I have read elswhere that 220 is fine enough but I always thought that smoother was better.
Thanks for your time I have read a lot of your previous posts and am more than happy to accept advice from a woodworker who is also a "lady". (no insult or condecension intended)
Dan
Westpest,
Apply Danish oil in the same fashion as you did originally & let father time do his thing. Jarrah will darken with exposure to light & the top will even up fairly quickly.
Don
Hi Dan, I never take exception when someone nice calls me a Lady! :-)
Here's the link to a thread named "Highest Sandpaper Grit". I can't vouch for the efficacy of the theories presented there, but I think it's worth reading. You might find #4 in the thread especially interesting.
http://forums.taunton.com/n/mb/message.asp?webtag=tp-knots&msg=5756.1
I too am a relative novice in finishing, and have been looking for more info on using pre-mixed oil finishes such as Danish Oil. I printed out the article at the following link and read through it last night. Reading it from beginning to end gave me a much better understanding of how to get a good finish with Danish Oil and how to correct mistakes that I might make. You'll need the Adobe Acrobat reader to view it. (If you don't have Adobe, you can download it at http://www.adobe.com/products/acrobat/readstep.html .
Here's the article: http://www.wwforum.com/faqs_articles/oil_finishes.pdfforestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Hi again
Thanks for the threads, I have read with great interest and I will follow some of the advice. I have a rather rhetorical question but it is something that makes me wonder about all the sanding advice...when is for example, 180 paper 180 paper ?. If you use the paper for a little while and of course is wears, does it not then become..190/200/etc..etc. probably a stupid question but us aussies have teflon shoulders and the ridicule just slides off.."have a go mate"
Dan
Hi Dan! Must admit, the more I read about sandpaper and such, the more amazed I am at how it's not simple. Turns out there are several (2 or 3 main ones) systems of numbering sandpaper, lots of different backers and binders and coatings and such. To vaguely answer your question though, I don't think that conversion would take place because the grit in your paper is not going to divide up into nice small(er) particles. The grit in the higher #'d papers is relatively uniform and well-distributed. The big grit in, say 100, paper is going to wear unevenly as you sand, not divide properly and re-distribute evenly. With the goal of sanding being to produce a uniform suface, the worker needs to progressively sand with finer and finer grit, and if the sandpaper has a few of those big dudes coasting along, the gouges will be strikingly ugly.
Some article I was reading recently (too sleepy to remember where) discussed a type of paper (or numbering system?) wherein the size of the particles was more uniform than in our sandpaper -- in other words, there was not as much of a range of particle sizes in one sheet of, again say 180 grit.
Oh dear, entering stream of semi-consciousness. Time to go to bed. Nite :-)
I don't remember if I suggested this before, but you might want to go to:
http://www.homesteadfinishing.com
and go to the abrasives section. Jeff Jewitt is a well-known finisher who also, I think, owns Homestead Finishing. There is some good info on their web site.
Edited 6/16/2002 2:51:47 AM ET by forest_girl
Dan,
Are these glued butt joints? If so is it possible that the glue was drawn up through the end grain and sealed the wood close to the finish surface?
Alan
