Can anyone recommend a Tooling company or Machine Shop service that can enlarge the bore on various saw blades?
I have a set of HSS Slitting Saws, 40 tooth x 5″ x 1/8″ x 1″ bore (Grizzly G9499) that I need bored out to 1-1/4″ to fit on a 1-1/4″ shaper spindle shaft.
I also will need several 10″ carbide-tipped blades bored out from standard 5/8″ bore to fit a Hammer/Felder saw arbor (1″ plus locating holes).
Rich
Try Ballew Saw & Tool. If they can't do it, they might be able to send you to someone who can.
http://www.ballewsaw.com/
Thanks bd.
Forrest Manufacturing will bore the blades. The arbor hole is 30mm not 1". The pin hole spec is 2/9/46.35mm (2-9mm holes on 46.35mm centers. My favorite blade for my Hammer is the Freud Fusion 300mm. The bore looks like it was machined as I see very fine evenly spaced tooling marks. Freud used a 3/8" bit for the pin holes, it works fine but I expected a nicer job from Freud. The Fusion gives an excellent cut and chip free cuts on plywood. I did not have any of my blades re-bored. Since the saw will use up to 300mm/315mm blades that is what I use.
I also have a Tenryu IW-30050CBD3 that was $80, inexpensive for such a high quality blade. It cuts like the Tenryu Gold Metal I used on my Unisaw, which was the best blade I ever used on the Unisaw. It produced excellent cuts in hard wood, was quiet and felt effortless when cutting. I have not tried this blade since I got the Freud Fusion but I will again soon.
"Life is not a success only journey." Dr. Phil
Edited 10/16/2008 7:57 am ET by JerryPacMan
Edited 10/16/2008 1:56 pm ET by JerryPacMan
Thanks Jerry.
Rich, I had the wrong part number in my post. It is a Tenryu IW-30050CBD3 and it was only $80. It is really an excellent blade and made in Japan. I recommended it over on the FOG and a user bought one and was impressed. It was factory bored and has keyhole style pin drive holes to allow use on other saws with a 30mm bore size. I talked with Ian at Tenryu USA and he recommended it. He sent it to my local dealer and told me to try it and if I liked it purchase it, if not just return it to the dealer. This was excellent customer service from Tenryu.
Rich, here are links to a couple of testimonials on the Felder Owners Group you can read if you are registered.
http://finance.groups.yahoo.com/group/felder-woodworking/message/45961
http://finance.groups.yahoo.com/group/felder-woodworking/message/46258
Edited 10/16/2008 9:20 am ET by JerryPacMan
Edited 10/16/2008 9:24 am ET by JerryPacMan
Edited 10/16/2008 9:32 am ET by JerryPacMan
Edited 10/17/2008 2:27 pm ET by JerryPacMan
