Hi everyone.
Will Titebond’s Melamine glue allow me to glue directly to melamine surface? For example, when joining cabinet parts edge to face?
Thanks for any advice
Hi everyone.
It prefers one uncoated surface and one melamine
Ok thank you. Yes that was what I meant, cut edge to coated face.
Glue Melamine
Webby,
I've never used the melamine glue, but I work with a good ammount of melamine when makeing shop cabs, or economically priced cabinets. Here's my thoughts on the process: The joint strength, regardless of how strong the glue bonds to the melamine surface, is still dependant on how strong the melamine is bonded to the substrate.
Generally, when I want to glue melamine, I try to cut shallow rabbets or dados, and use plain yellow glue. They only need to be 1/32 of an inch deep, just enough to remove the plastic coating, and expose the substrate. Now I've got an actual wood to wood joint, which makes me feel better atleast.
Hope this helps,
Thanks for the advice. I was planing on a shallow dado.
Melamine glue
Yeah Webby, that's what it's made for. I've used Roo Glue for many years in making Melamine cases. It's the same type of glue as the titebond melamine glue , althought it's been around longer . You can use a shallow dado and use regular yellow glue as another poster has suggested,but as far as strength goes there's little if any difference and that just adds more work to what your trying to accomplish. I went through that transition many years ago and I've found that you get a better finished look when you don't use dado's, so why add another step. I would suggest using dadoes only where you can't get in screws , nails or staples as an additional mechanical support.
