I am about to glue up the head and foot boards for a bed I am making. I would like to have as long an open time for gluing as possible. Any thoughts/suggestions on using the TB hide glue? Thanks in advance.
Kieran
Kieran
Make sure the glue is not out dated. Per Frankling Glue Co. it has a shelf life of one year and most bottles I look at in my local hardware store are out dated. I have to purchase it 60 miles away where it truns over faster. It will give you a longer open time but is sticky and a little more difficult to clean up the squeeze out. Good luck, I have used it for about 15 years and have had no problems with it.
I use "Old Brown Glue." It has to stay in the clamps for a good while but you can adjust things and do other fiddeling without the open time "pucker factor."
Kieran,
If you want long open time, polyurethane glue is a very good choice. I have used Gorilla Glue on all kinds of woods, even oily tropical woods with excellent results.
Follow the instructions about making sure the glue surfaces are clean, freshly-jointed (if possible) and slightly dampened.
I try to apply without much excess, but any squeeze-out can be cleaned up with a rag and acetone (after the "foaming" stops and before the glue starts to set) without leaving a trace, staining the wood, or preventing stain or oil penetration later.
Rich
Thanks to all who took time to respond. I ended up going with the TB III. It seems to have worked out fine and one more relatively stress free glue-up is history.Kieran
