i’ve been going between my regular tablesaw blade and my stacked dado set. i’ve just noticed that my regular blade no longer lines up with my zero clearance insert or my crosscut sled. it’s as if the whole blade has shifted over maybe a sixty-fourth of any inch to the left. how did this happen? how do I fix it? help!!
Start Your Free Trial
Did you move the saw recently - especially by holding the table top for leverage? Maybe after a cold night. The top may have shifted. Common occurrence. If so, you may have to loosen the table top bolts -- usually 3, and realign / tighten.
Don't over tighten -- cast iron breaks.
Boiler
If you have a cabinet saw, the top has shifted and you will have to realign it. It's pretty easy--there are 4 bolts that connect it to the cabinet and they get loosed and retightened. It takes a bit of "futzing" just because the top can shift a bit as the screw tightens. Make sure of the parallelism of blade to miter slots.
But, with a contractor type saw, the trunnions are connected to the table and have shifted and you have to realign in a more complicated process adjusting the trunnions relative to the table. I haven't aligned a contractor's saw in a month of Sundays so I'll leave it to others to help with the fine points.
If there are loose washers that go on each side of the blade you may have swapped them. There would only need to be .008" difference in their thickness to move the blade over 1/64"
Rich
The Professional Termite
Are you sure what you stated is true, or did you just notice that your regular blade is away from the kerf? The dado blade may have more set than the others.
On my old sleds, I usually have a sacrificial piece of 1/4" mdf between the sled and parts to keep down the chip-out, and improve accuracy. If you have not moved the saw, or run your car into it, I wouldn't think you should be worrying about change. But maybe you should talk to your wife and or kids about parking near your saw. %]
Edited 9/10/2009 11:09 pm by KeithNewton
Your arbor could have moved for various reasons.
Life is what happens to you when you're making other plans.
When your ship comes in... make sure you are not at the airport.
Sean,
as I read this thread, I was watching a rerun on TV of an episode of The Twilight Zone. There are many possible explanations of the phenomanon you referred to. :-)
As you see the variety of possibilities, it would help us help you if you could provide some more info about your saw--make and model for example, how long you have had it, and when did you first notice the problem.
Longshot, could you inadvertantly left a shim from your dado set on the arbor before instally the blade?
