Table saw will not tilt to 45 degrees.
I just bought a used Craftsman 10″ belt driven table saw. To my dismay, it seems that the blade will not tilt to 45degrees and therefore I will not be able to make a square corner. Any ideas on how, or if, this can be fixed. I have turned the adjustment crank as far as it will go and it is solidly stopped with the blade at 43 degrees. Since I want to make small boxes, this is not good. Thanks in advance for any help.
What is providing the solid stop?
Is it an adjustment bolt that needs to be retracted a bit?
Cheers, eddie
There should be an adjustable stop for the 45 and 90 degree stops. All the craftsman saws Ive seen the adjusters are allen screws on the top on either side of the blade insert. If it's a left tilt it should be right side is 45 degree and left is 90 degree stops. Basically you unscrew it then turn the hand wheel till its correct then tighten it I believe. Good luck!
mike
Many of the older Craftsmen saws have a collar with two, at least I think it is two, set screws, one on each side of the collar, and one collar on each side of the acme treaded shaft. These collars control the 90 degree and 45 degree settings.
They can be knuckle busters! Good luck.
Doug
Thanks to all who offered advice. Doug was correct about the collars. I have to get a flashlight to see if there are set screws in the collars or not. At any rate, it's good news that it is adjustable and that I didn't waste $100 when I bought the saw. I also bought a 12" Craftsman bandsaw for $50 and traded a basement sump pump for a Craftsman 6" joiner. My old boss sold out and is going to live full time in a motor coach. Since I just retired, I will have time to put some of this to good use. BTW How do you put in a carriage return on this board? My enter key doesn't.
At least one set screw is in the collar whether or not you can see it. Rotate the crank until you see the the screw. They are brass and usually show us fairly well if you use a flashlight. It is kind of a three hands job and is trial and error. Rotate the tilt crank in orer to take the pressure off of the collar and expose the set screw.
It's a terrible design but if you tightening the set screw well enough, the stops usually do not shift. I have a craftsmen TS as my primary TS until 2 months ago and the stops have been set for about 4 years without any need to adjsut them. It was my first major power tool and we have been together for 35 years, ten relocations in six states, and I really don't have the heart to get rid of it. So, I keep it as my backup saw when the new TS is set up for a specific function such as cutting dadoes.
Anyway, glad I could help.
Doug
Have a craftsman 10" too. same problem. Also doesn't retract below table all the way. (1/8" or so sticks up thru insert). Will try all the suggestions and let you know. You ever have that problem too? Brian
No, my blade goes all the way down. However, I think the cure is the same. There is a long screw attached to the crank with stop collars which limit the adjustment. If you move the collar further to the end of the screw, your blade should go down.
I'll let you know. Thanks.
New,
Hope you're not looking at the indicator on the saw to obtain your 43 degrees.
Mack
No, my father was a tool and die maker and I got all of his tools when he died so I can accurately measure the degrees of tilt without using the gauge on the saw.
what type of fence system do you have? i have a biesmeyer and it does not tilt all the way either.
I'm lost. What would the fence have to do with the arbor not tilting to 45 degrees?
The fence is the Craftsman fence that came with the saw.
