Hey All!
Has anyone found upgraded pullies for a Powermatic 64C table saw (built in the 90’s)? I did contact Woodcraft regarding their selection and they recommended the Delta upgrade (pre-1988) package. They did say that there may be some ‘slop’ in the pully key but should not effect the performance. I did use the Woodcraft pullies on my previous Craftsman saw and thought that they were outstanding, the link belt too.
Any information you all may have would be appreciated!
Goodtimes
You can buy the pulleys you need, with the correct size keyway, directly from a machine supply catalog like Graingers or MSC or, if there's one nearby, a local industrial supply house. They'll also have the link belts and the price will probably be better. Often times, replacing the belt is all that is needed, try that before you go through the extra work and expense of replacing the pulleys.
John W.
Thanks John!
The only reason for the change is that, some how, one of the pullies got distorted. I do have a link belt already. What a great invention!
Thanks again!
Yeah, I love them.
John W.
