I am looking at table saw splitters. Kelly Mehler in his latest book on table saws didn’t have an opinion on the Merlin splitter. Have any of you had a chance to compare the Merlin against some of the others such as Biesemeyer. Would appreciate some guidance. Thanks Chuck.
Delta's is OK, but not great. It came in a standard kerf size, and I found out after the fact. I use small kerf blades, so it is worthless to me.
Boris
Chuck, I have the Merlin on my older Jet contractor saw. If I had a choice, I would rather have the Biesemeyer, for two reasons: The Beis is a little easier to "be rid of" than the Merlin (drops below the table rather than having to be taken off) and the Merlin sometimes won't go over far enough for a 45* bevel cut without some fussing.
That being said, the Merlin has performed extremely well for the ripping I do, which has all been regular 90* ripping. It's on there solid as a rock, and I can bump it with stock and it stays lined up. It also retains alignment when removed and replaced repeatedly. This is somewhat surprising, since it isn't even made specifically for my saw -- saw is too old. I did a little creative engineering and got it installed. Very happy with it.
forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I made my own by planing a piece of white oak down to kerf thickness. Have it installed on my 10" Rockwell contractors saw. Required a couple of brass shims to get it aligned with the blade.
Hi Planewood!, I'm assuming your throat plate is a shop made wooden one? Did you just glue the splitter to the throat plate?
I'm afraid I run my saw without a guard or splitter ( I Know I Know!!) but want to change this situation. I'm considering HTC, Merlin etc.....
Thanks, Brian
Brian -
No, my original aluminum plate has a opening behind the blade for a splitter. There is a bracket underneath the table for bolting the splitter in place. It's an old Rockwell 10" contractors saw. About 30-35 years old.
I have made zero clearance plates out of wood (Mahogany) with such a slot.
Besides reducing kickback, use of a splitter will result in cleaner cuts.
I have the Beis on a Jet cabinet saw. The pawls were more trouble than they are worth so I cut them off so there's just the shark fin. Left to my own devices, if I ever need a thin kerf spliiter I'd get some scrap 1/8" T6 aluminum and thinkness it to match the blade above the throat plate and use the steel one as a template.John O'Connell - JKO Handcrafted Woodworking
I have the Beis. I like it. You can use it with an outfeed table much better than the other models. Just pop it in or out.
Thanks Terry--I think I will go with the Biesemeyer. It's sturdier but cant use a thin kerf blade with it, but I can take it out then. Thanks, Chuck.
Terry's point was an excellent one -- I'm glad he brought it up. One possible option for when you have to remove the Beis -- you can drill a hole in your tablesaw insert and place a "pin" of the appropriate size for a splitter. Or even a thin wooden wedge.forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Thanks Forestgirl--I read that one in Kelly Mehlers text on table saw book. A good idea. And simple too. Chuck.
Terry, I hadn't thought about the outfeed table factor, as I've not made one (yet). Good point!!!! Will give me something to think about when the time comes.forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Chuck, something else that Kelly told me (which I have done) is to buy the Felder splitter and the plastic guard that attaches the splitter, all for a total of less than $100. The guard removes with a simple hand bolt, has a 2" duct collection port.
The splitter has to be redrilled to adapt for your saw, no bit deal, I did this for my general saw. It doesn't pop in and out like others but it's great improvement from having no splitter at all.
Bill
BillSams,
You said for your "general saw." Is that as in a General 350? If so, can you tell me a little more about what you did with the Felder splitter?
I have a General 350 and would like to upgrade the splitter. Any info you can provide would be appreciated.
Alan -- planesaw
Alan, yes it was for the general 350. The felder splitter has a long curved slot for attaching to the felder saw, so you have to drill a 3/8" offset hole for the general bolt. You will also have to cut off some of the bottom of the splitter and slightly notch for the table insert to fit under. If you send me your email address I will send you a photo which will explain it all much clearer.
On http://www.felder.com website they have 3 thicknesses of splitter, I went with the middle thickness, but if you use thin kerf blades you will need the thinner of the three.
Bill
Thanks, BillSams, I'll look into it. With appreciation, Chuck.
